fuel issues posted by ZfreakTT on June 04, 2011 at 10:45 AM
check your fuel pump voltage while you're turning the motor over it should be 6 or 7 volts. if its not getting any volts its probably your fuel pump controller which is located behind the drivers seat. If it turns out to be your fuel pump you can get one at autopartswarehouse.com I got mine there and it was the same brand as the autozone one but $100. cheaper.
